H20GAL:
I sent you a message, last night, it seems that the site either lost it or stayed in the Ciber space and it is lost.
Where are you located ?.
The site does not have capabilities to send a copy to my own email address, to bad, it had all the calculations for the site.
9 meters head is best for a "Banki"
I calculated 110 liter/sec that gives 9*110*9.81= about Gross 9.7 KW, so with 60 % efficiency you may get 5.8 KW.
Does the creek have fish ?.If so just 50 % water may be the maximum you may take.
A Turgo Turbine is a possibility if you built it to your diameter required to your site.
The Turgo Turbine would be a small diameter for a 4 pole generator that will require a full flow nozzle ( a ring nozzle) for 110 l/s.
The diameter would be 0.1 meter= 10 cms= 4 inches with some large size spoons.
Pelton is out.
Contact me directly if you desire more information
Regards and good luck
Nando
nando37-at-comcast-dot-net
