Author Topic: testing welder output  (Read 1615 times)
blueyonder
« on: January 09, 2008, 01:20:07 AM »
 hi i have a small stick welder its says its a 140. but not sure what that means.
  i have done sum good work with it . i do understand i unscrew the big nob on front it will lower the current.  screw it right in then its on max.
  never had much luck trying to weld thin stuff.  i spend more time trying to fill the holes ive blown in it .thin pipe or sheet.
 i got a good earth clamp and a nice rod holder.
  its only a small basic welder.   but i need to try understand it a bit more.
  now i ask can i put a meter set dc.the the earth - tongs.
  positive negative.
  ive never measured the volts dc.
  but a friend once measured the ac going into the welder . he said sum times the grid can be down  and i can have problems welding  .
  grid down on volts i mean . not shut down.
  all the years ive had i never give it thought..
 i got a meter with 1000 volts dc setting on it.
  im just getting more interested now in dc and ac readings.
  i do understand i cant go near it with amps.
 i am fed up letting the magic smoke out all the other meters in the past.
  i will wait and see if i get a reply and if not will give it a try.
 it wont kill me but it might make just a bit smoke. not sure.
Maybe a Diary? Seems kind of off topic in main foeum?
« Last Edit: January 09, 2008, 01:20:07 AM by (unknown) »
