It may be a basics question, but I have 2 48V PMA wind turbines, each one 1KW rated.
Then, I have 4 12V UPS batteries, in series for 48V, that I want the two turbines to be connected to.
I am also using a voltage sensor/relay to activate a dump load.
My questions;
i-Do I simply connect the + & - leads coming out of both the turbines into the + & - terminals onto the batteries?
ii-Or should I connect the turbines in parallel first using a connecting strip and then connect them onto the battery's terminals,
[but aren't these (i & ii) both same ideas? And if so, I have read in the board comments as not to connect the turbines, in either parallel or series connection! For unknown reasons]
iii- In last, where do I connect the voltage sensor? Onto the same + & - battery terminals, where I have already connected the turbines?
Again, these may sound very basic questions, but may be helpful to other board members as well.
Dave.
