yes i'll try not to be so vague, i was thinking along the lines of a banki style turbine. i saw the write up on scott's dam, where he constructed a small hydro unit in this fashion. it's the first page that pops up when i hit otherpower in my bookmarks. i live about ten miles from the closest power line, phone and computer are by bag phone, heating is outside wood boiler and kitchen barrel stove, electricity comes from a diesel generator to a trace 4024 inverter/charger also a couple of windmills. hydro would be a beautiful thing if i could figure it out. my creek is about 12'-18' wide and only 2'-3' in the deepest areas. it is not very fast maybe 2mph. i figure the most head i could achieve would be about 4'. i am trying to figure a few things out before i get started, maybe it wouldn't be feasible, i don't know. at this point i can't get an accurate measurement as in the spring the creek is ten feet wider and much faster and deeper this will continue for a few more weeks before things settle down. the hydro plant that scott built has 12" dia. side runners and 10" long vanes, would 24" diameter runners with 20" vanes make a considerable difference? the rotor are 11" dia. with 12 magnets per rotor, does the number of magnets or the diameter make a difference? the stator has nine coils of 125 windings of #17 wire are more windings an advantage? would it make any sense to incorporate a shaft through the center with pillow block bearings on each end and add another rotor/stator setup on the other side? am i lost or is there hope? corny
