Author Topic: to heavy?  (Read 1456 times)
mitch1965
to heavy?
« on: January 25, 2009, 04:10:48 PM »
i've got a dc stepper motor. the only problem is its weight- 100 lbs. by the time i finish the mount and tail i'm guessing 140 lbs total. i have a rhom cb tower 30 ft tall. dont wont to fold my tower trying to raise it. have a tilt hinge mount and use a hand crank winch to lift it.the motor is a real power house,and would really like to fly it. anybody think the tower would stand up to the lifting?
« Last Edit: January 25, 2009, 04:10:48 PM by (unknown) »
electronbaby
    • Windsine.org
Re: to heavy?
« Reply #1 on: January 25, 2009, 10:34:36 AM »
depends what type and model of Rohn. if its a stamped steel model, i would advise against it. If its a 45G or larger than go for it. There are many variables.
If you are scared to lift it with the machine on it, then how do you expect it to stand up to heavy winds and not collapse?
« Last Edit: January 25, 2009, 10:34:36 AM by electronbaby »
Have Fun!!!  RoyR KB2UHF
Re: to heavy?
« Reply #2 on: January 25, 2009, 09:07:20 PM »
Leave it on the ground and better suited to a
VAWT in your case.
Heavy motors like this is for more experienced
people to be hoisting in the air.
You gave no data on this either just because it's
a big stepper motor doesn't mean it will be
suitable as a wind turbine what diameter is the
WT ?
« Last Edit: January 25, 2009, 09:07:20 PM by Norm »
mitch1965
Re: to heavy?
« Reply #3 on: January 26, 2009, 05:39:34 PM »
ok im not real sure but its not stamped steel. it is tubing with z shaped bars and double bolted at each conection joint.seams to be well bulit. i got 60 ft for free so i cant complain. it is down now and i tried putting all my weight on it 220 lbs- didnt bend it so mabey it will hold?
« Last Edit: January 26, 2009, 05:39:34 PM by mitch1965 »
mitch1965
Re: to heavy?
« Reply #4 on: January 26, 2009, 05:45:48 PM »
hi norm - this motor came from surplus center- perless motor- testing at 70 rpms 15 volts and blowed my fuse in my shunt meter on amps-10 amp fuse- so i guess it should do ok-
« Last Edit: January 26, 2009, 05:45:48 PM by mitch1965 »
