Author Topic: Wire to 1000 Watt Wind Turbine to Battery Bank  (Read 6884 times)
sublime21
« on: March 28, 2009, 07:51:33 PM »
Hi, I have a 1000 watt generator. It is rated for :
  1. Volts DC
  2. Amps
  3. RPM'S
The Distance from my battery bank to the turbine is 85 Feet. So would that mean 170 feet for both wires?
Problem I have is a calculator online tells me to use #4 AWG, but I was hoping I could maybe have a couple runs of some less expensive AWG.
I'm new at this and any help is greatly appreciated.
« Last Edit: March 28, 2009, 07:51:33 PM by (unknown) »
Re: Wire to 1000 Watt Wind Turbine to Battery Bank
« Reply #1 on: March 28, 2009, 05:38:42 PM »
Sounds like a treadmill motor and won't see anything over 100  watts max into a 12 volt battery and will probably need to settle for charging a 60 volt battery and one at a time . So put your gen set as close to the batts as possible .
Charge the 6 volt batteries  in parallel and use as 12 volt with transfer switch If you need a diagram I'll post one . The treadmill motor is dc and looses a power with long runs . Get the unit up and working you'll see the problem.
« Last Edit: March 28, 2009, 05:38:42 PM by tecker »
« Reply #2 on: March 28, 2009, 05:40:03 PM »
That's 6 volt battery (typo)
« Last Edit: March 28, 2009, 05:40:03 PM by tecker »
sublime21
« Reply #3 on: March 29, 2009, 09:13:50 AM »
Thanks for the reply Tecker. I bought the motor off of Ebay.
This is the link of it.
http://cgi.ebay.com/BIG-1000-WATT-WIND-GENERATOR-TURBINE-MOTOR_W0QQitemZ260382439748QQihZ016QQcatego
ryZ42920QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Will I have to use 4 AWG Wire? It would be nice to run a couple of smaller wire lengths.
If you want you can post a Diagram.
« Last Edit: March 29, 2009, 09:13:50 AM by sublime21 »
« Reply #4 on: March 29, 2009, 07:43:56 PM »
8 amps and 170 feet is 3.4 volts loss.
« Last Edit: March 29, 2009, 07:43:56 PM by joestue »
« Reply #5 on: March 29, 2009, 07:44:15 PM »
(14 gauge wire)
« Last Edit: March 29, 2009, 07:44:15 PM by joestue »
Basil
« Reply #6 on: March 30, 2009, 04:58:22 AM »
I have a 38 volt motor rated at 12 amps and all I ever see is little more than 2 amps. I use a 100 ft 12 gage extension cord from the hardware store. They are fun for learning but not much for charging. I call my the battery maintainer not charger. I have had mine up for about a year. When the wind is blowing I still have to check to see how much it's puting out. I plan to put up another one soon. I love mine.
« Last Edit: March 30, 2009, 04:58:22 AM by Basil »
« Reply #7 on: March 30, 2009, 06:34:23 AM »
85 feet is not going to get you much power and so  a closer install is a  must but you have to  have good wind though so best guess there . getit up and post back with the max voltage and amperage through a 6 volt batt.I'll post a diagram latter.
« Last Edit: March 30, 2009, 06:34:23 AM by tecker »
« Reply #8 on: March 30, 2009, 06:42:49 AM »
It looks like it would be OK with #8.
http://www.windsun.com/Hardware/Wire_Table.htm
May be a bit cheaper to run 2 pieces of 10-2 UF, giving the same result as #7.
A 250' spool would have wire left over.
Don't use solid wire down the tower.
« Last Edit: March 30, 2009, 06:42:49 AM by ghurd »
sublime21
« Reply #9 on: March 30, 2009, 11:41:21 AM »
Thanks for all the comments.... I'm still learning this , would be nice to have it up and running tho. For now all I have are a couple car batteries...... Any idea which would be the best wiring method?
« Last Edit: March 30, 2009, 11:41:21 AM by sublime21 »
« Reply #10 on: March 30, 2009, 12:21:58 PM »
Have ever given any thought to setting up your dump load to  charging 6 and dumping to 6 with the dumper in the common .
« Last Edit: March 30, 2009, 12:21:58 PM by tecker »
« Reply #11 on: March 30, 2009, 12:51:37 PM »
You lost me with "the dumper in the common".
I do not like attempting to match the exact charging amps with the exact dumping amps.
No need for it to match as far as I can tell.
My simple circuit can keep the voltage with in 0.04V anyway, and I was told that is not as good as 0.1V or higher for flooded cells.
The thing works faster than people expect.
« Last Edit: March 30, 2009, 12:51:37 PM by ghurd »
« Reply #12 on: March 30, 2009, 01:01:30 PM »
Honest?
The generator is a low % of the cost.
I would aim for a lower output of the "1000W" item you have (like 100W),
but try to get it at 12V.
If it can not operate at the system voltage, what's the point?
Can't split car batteries into 6V banks anyway.
« Last Edit: March 30, 2009, 01:01:30 PM by ghurd »
« Reply #13 on: March 30, 2009, 08:06:10 PM »
It looks like he took some 2.5HP surpluscenter treadmill motors and put a hub on them.
They will make ac when you spin them. You would do better to take ac from it and rectify it near your batteries. You may have to move the blocking diode, depending on where it is.
100 watts is all you will likely get. A 100-foot 12-gauge extension cord should work fine.
« Last Edit: March 30, 2009, 08:06:10 PM by dnix71 »
squatter1
« Reply #14 on: July 09, 2009, 05:29:37 AM »
Hi, I've have been reading and learning as much as possible in this forum and I've gotta ask; Why not use soild wire ie;10/2(3-phase)inside the pole and why you can't let it twist?
 Also while I'm here whats the deal on "furling" . I can't seem to find much on the subject. Thanks
« Last Edit: July 09, 2009, 05:29:37 AM by squatter1 »
« Reply #15 on: July 09, 2009, 06:51:25 AM »
Solid wire can not take the flexing and will break.
May have a problem getting it without kinks, and the kinks would rub the pole until the insulation failed.
Furling is how a windmill "folds itself" in high winds.  It takes the blades sideways to the wind to protect itself from too much current or too many RPMs.
Easier to see than explain.
Photo,
http://www.windmills.net/images/water_pumping/windmill.gif
Video,
http://www.youtube.com/watch?v=MlysuiRf0wQ
« Last Edit: July 09, 2009, 06:51:25 AM by ghurd »
