I have seen that discussed before. The simple test to know which way to make your blade spin was to take the front wheel of a bycicle and spin it while holding onto the shaft. Turn toward the direction your generator will furl and the wheel will either want to turn up or turn down. If it turns down, then make your blades spin the other way. During a hard furl, your blades will want to pull away from the tower shaft.
