Depends on the axis about which you spin it and the geometry of the coil it is spinning in.
If it produces anything it will be ac.
It will produce no power unless there is a circuit for current to flow even iof you produce an emf.
In the form that you probably have in mind I suspect it won't work, but I can't read your mind.
