Author Topic: Inverters in parallel  (Read 1021 times)
Bosman
« on: October 20, 2008, 09:08:27 PM »
I have 2 inverters/ One 300W and the other 800W. Can I connect them in series to supply a single 1KW load?
« Last Edit: October 20, 2008, 09:08:27 PM by (unknown) »
mettleramiel
Re: Inverters in parallel
« Reply #1 on: October 20, 2008, 03:54:47 PM »
That entirely depends on the inverter, but seeing as they are that small, I would have to say no. Besides, think about the wiring in the 300 watt model. All the current from a 1KW load, so about 80amps will have to flow through it. Not likely that anything in there could take that kind of load.
« Last Edit: October 20, 2008, 03:54:47 PM by mettleramiel »
wpowokal
« Reply #2 on: October 20, 2008, 04:43:10 PM »
I agree they can not be stacked and certinally not connected in series.
An inverter has to be manufactured for stacking, I know "Outback" can although I don't use them for personal preference reasons. Basically they have to syncronise their output frequency and voltage in a master slave configuration, ie one is the lead and the other follows, but they share the load.
Also 1100Watts is unlikley to run a 1000W load unles it is all resistive.
allan down under
« Last Edit: October 20, 2008, 04:43:10 PM by wpowokal »
