Hey All,
Just thinkin' out loud here, feel free to chime in and cut it to ribbons if you like. I haven't put more than a few hours of thought in on this yet so it won't hurt my feelings one bit. Not trying to reinvent the wheel, pretty similar to an induction motor in many ways and there are probably others who have gone this route in making an alternator, I haven't really looked. My thoughts stem from using what I have around or can easily obtain and my belief that using the greater speed at the perimeter can be used to some advantage.
Another low budget build here.
Magnets: 28 Neos 1/2" Diameter x 1/2" length
Coils: 21 wound one direction - number of wraps and wire size TBD
Rotor: ~9" Diameter
Wiring: 3 Phase Star
Cut-In: ~200 RPMs - TBD but this is my estimate at this time
Blades: 3 with 5 blade option
Diameter: 36" to 60" - Depends on coil wraps and wire size TBD
Voltage: Anybody's guess but hoping for 14.2V min. @ 300 RPM under light load
Aperage: Very Low
My reasoning here is that I would like to use a 9" Diameter brake disk for the rotor. I don't know how hard the steel is, hopefully it can be cut with a hacksaw or jig saw then the bottom of slot filed to shape.
An axle assembly with hub and disk would be ideal. Perhaps I can find one for a small car, ATV or riding lawnmower that would work. Ideas?
If there is no backing plate then I will manufacture brackets to mount the stator.
(I even thought about making a laminated rotor but I'm not sure if I would gain anything and manufacture would be a bit more work I think - haven't ruled it out entirely yet)
Currently I don't have a clue of what would make the best laminated stator rings but if I can use sheet metal then I know I can make them. I am assuming they need some insulating layer between plates to cut down eddy currents but I'm hoping this design will provide a good path for the flux lines to follow.
I would probably rivit the plates together to keep them tightly compressed and uniform. Drilling is relatively easy and if I chamfer the holes for the windings and break sharp edges I should be able to avoid shorts. I would likely impregnate the coils with super glue or resin if I can figure out a way to keep it contained and to get it to penetrate well. I suppose I could just cast the stator one side at a time if you think it's needed.
arc
Slim Compact and fairly lightweight overall.
Lamination should be nice and rigid, just lots of holes and slots to cut.
Holes in Laminations will be drilled then sawed after to cut the slot.
Here I've removed the Laminations to get a better view of magnet to coil relationship.
Spacing is shown with 28 Magnets and 21 Coils.
Nice narrow air gap is the plan
Inside diameter of coils is 1/2" wide x slightly longer legs.
At least 4 Stand-offs using threaded rod to allow for adjustment.
