Author Topic: Step by Step Photo Uploading /Use on OP  (Read 215 times)
« on: March 30, 2003, 08:19:33 AM »
First and foremost log in
Then on the right in one of those textboxes there should be one with your nickname [username] in it. In that box is an option "Your Photo Uploads".
Click on "Your Photo Uploads" and then you can follow the directions to uploiad the photo or file to your upload area.
Ok now the photo is uploaded to an area on the www.fieldlines.com server where anyone can access it from the internet.
All fine and good.
Finally we get to actually use that photo in a posting.
From the front page or perhaps others on the right again select "Submit Posting" from the menu.
Once that page loads you should see a box on the right for "user Files". Use the pulldown menu to select which of your files to use click the button to insert it into the message.
Simple as that.
Much easier to do than explain.
« Last Edit: March 30, 2003, 08:19:33 AM by (unknown) »
elvin1949
Re: Step by Step Photo Uploading /Use on OP
« Reply #1 on: June 19, 2003, 08:33:43 PM »
tomw
thanks
like the dummy i am
i PRINTED IT OUT
elvin1949
« Last Edit: June 19, 2003, 08:33:43 PM by elvin1949 »
