Author Topic: Screwed up my diary entry on 10 footer  (Read 221 times)
halfcrazy
« on: January 11, 2006, 11:42:54 PM »
ok i posted a diary entry but the pics where huge so here goes again
here are a couple in self etching primer
heres a couple with the tail mocked on so we can do all drilling before paint
this one should show the 5 degree tilt of the spindle
couple after paint showing the metalic paint
this one should show the furl stop i added i actually notched the tail pipe to much so this seemed like a shure fire way of keeping the tail outa the blades.
got my magnets and rotor discs from dan today so i can get started on those and then a stator. will keep the updates coming
« Last Edit: January 11, 2006, 11:42:54 PM by (unknown) »
Re: Screwed up my diary entry on 10 footer
« Reply #1 on: January 11, 2006, 06:43:05 PM »
You can just resize you pictures and upload them with the same filename as the ones you want to replace. Then both your diary and your story will be fine. Thanks for noticing and disregard my comment in your diary.
« Last Edit: January 11, 2006, 06:43:05 PM by wooferhound »
halfcrazy
« Reply #2 on: January 11, 2006, 07:10:27 PM »
thanks wooferhound problem solved i think
« Last Edit: January 11, 2006, 07:10:27 PM by halfcrazy »
