Author Topic: The light weight question  (Read 325 times)
Devo
« on: October 04, 2007, 10:22:16 PM »
As Ed as shown with his 200 watt mill , a lot of weight can be shaved to produce a fun little windmill. we should have some sort of 3 month contest just for fun to say make a windmill that will produce 50 or 100 watts of power in say 15 to 20 mph wind.
See who can come in the lightest , I'll bet you would get some unique outfits from this board we would need some sort of guidlines, anyone interested? -Just a thought...
Devin
« Last Edit: October 04, 2007, 10:22:16 PM by (unknown) »
Re: The light weight question
« Reply #1 on: October 04, 2007, 04:51:25 PM »
heres my motorhome mill-all wood[sawblade rotors][ceramic mags with neoes on top] -its survived 45-55mph winds so far-furls right up- not sure of the weight cant be much over 25-35 pounds--lights up 4 50w headlights in a good wind..its a 9 and 12 setup-with all six wires down the pole-for star or jerry rig...
« Last Edit: October 04, 2007, 04:51:25 PM by hiker »
jmk
« Reply #2 on: October 04, 2007, 07:54:07 PM »
Yes but is that wind at that level or do you put it up in the sky?
« Last Edit: October 04, 2007, 07:54:07 PM by jmk »
« Reply #3 on: October 04, 2007, 09:26:12 PM »
                heres a earlery version of the mill with longer blades
                and a diffrant base mount...mounted to back of motorhome
« Last Edit: October 04, 2007, 09:26:12 PM by hiker »
SamoaPower
« Reply #4 on: October 04, 2007, 10:52:16 PM »
Weight: 15lb, Power: 150W. Downwind.
« Last Edit: October 04, 2007, 10:52:16 PM by SamoaPower »
Devo
« Reply #5 on: October 05, 2007, 05:03:37 PM »
SamoaPower that's a sweet mill
Devin
« Last Edit: October 05, 2007, 05:03:37 PM by Devo »
Spdlmt150
« Reply #6 on: October 05, 2007, 09:55:32 PM »
It's not been a powerhouse, but for a $35 mill what do you expect? 12/9 dual saw blades with 1/2" square X 1/4" thick neos, pipe fittings, & threaded rod. I've seen it push 2A at 12v in a good gust. It's obviously in a poor location (best output is winter when all the leaves are gone - hope to see 4A then) Weight is maybe 15 pounds.
« Last Edit: October 05, 2007, 09:55:32 PM by Spdlmt150 »
