I think only two folks in the world know and understand how to use PROPID. And, they aren't talking.
I think there is a lot to be gained with the proper airfoil and twist in the whole scheme of things. For the 'hobby wind-farmer' I think time would be better spent other places for the small gains one would get in performance.
It is difficult to properly carve an airfoil correctly over several feet and repeat it three times. It is even more difficult if one uses a complex airfoil with reverse curves in it. It is difficult to even properly model and write the code to efficiently CNC carve the things.
Once someone understands the complexity of the problem, they will avoid carving for other peoples machines. Any mistake is likely to be blamed on 'the blades'. and to be correct, each blade set needs to be matched to the machine. That means each set of blades needs to be designed FOR that machine. And, few will say 'I want this' with a proper description.
They will say, 'I want a TSR of X' and have no flipping idea of what they speak. Or, ask the TSR of an airfoil ... I will guess they will be reluctant to pay a qualified aeronautical engineer to design the airfoil. They want it for X magnets and Y Turns of Z dimension wire and W volts ... but can't answer how much torque it takes.
At some time I hope to be able to understand and run PROPID. I wish it was a LINUX program as I might have it run in the background while I thought of how to play with it but, alas it is a windoze program. I don't suffer windoze well.
