Author Topic: "water-cooled" solar panels  (Read 2578 times)
Rabrsniver
« on: August 09, 2005, 05:15:36 AM »
I have read that solar panels are more efficient when they are cooler. Would it be feasible to install a drip or mist water system (on a timer of course) that would wash water down the panels to keep them cooler? Or would the water act as a filter and keep the sun from getting to the panels?
« Last Edit: August 09, 2005, 05:15:36 AM by (unknown) »
cr8zy1van
Re: "water-cooled" solar panels
« Reply #1 on: August 08, 2005, 11:47:40 PM »
I also had the same idea, but I wondered if I could run tubing behind the cells,
encased in plastic. Kind of like a watercooled heat sink, I have a couple extra
cells, and could even use them to power a small pump to move liquid around. I
dont want to over complicate things, but would like the best performance out of
this thing. Since I am still waiting for my plastic resin to show up, I can
still add tubing If its a good idea. I posted my progress
here if anyone wants to follow.
« Last Edit: August 08, 2005, 11:47:40 PM by cr8zy1van »
pyrocasto
« Reply #2 on: August 09, 2005, 12:38:11 AM »
It may work but I think you would be better off finding a way to cool the inside of the panel. Maybe a mini heat exchanger to fit in the back of the panel behind the cells.
Just remember not to use 10 watts to make 5. ;-)
« Last Edit: August 09, 2005, 12:38:11 AM by pyrocasto »
