Author Topic: Help with batteries...Please  (Read 1575 times)
altpwr
« on: August 27, 2004, 01:51:03 PM »
I have recently purchased VW solar panels (3 of them).  I plan on using a splitter (in reverse) to combine all 3.  This will give me a total of 9.6 watts.  Should I put a charge controller between the panels and the battery??
I have heard that 10 Watts is the magic number where a charge controller is neccessary, but I can't figure out why I wouldn't want a charge controller for a small system that will go a week or more without discharge.
Thanks for any info in advance.
« Last Edit: August 27, 2004, 01:51:03 PM by (unknown) »
Nando
Re: Help with batteries...Please
« Reply #1 on: August 27, 2004, 03:41:42 PM »
altpwr:
What is a splitter in this case ?.
What is VW panel, please explain you you get accurate help.
What is the voltage & current output of each section?>
What is the battery voltage.
Regards
Nando
« Last Edit: August 27, 2004, 03:41:42 PM by Nando »
commanda
« Reply #2 on: August 27, 2004, 04:13:14 PM »
I think it's the ratio of panel watts (and hence amps) to battery ampere-hours that determines whether you need a charge controller or not.
« Last Edit: August 27, 2004, 04:13:14 PM by commanda »
PaulJ
« Reply #3 on: August 27, 2004, 08:31:37 PM »
   Battery type is also important. Flooded cells are far more forgiving than SLA's where over-voltage is concerned, as long as the electrolyte level is maintained.
« Last Edit: August 27, 2004, 08:31:37 PM by PaulJ »
altpwr
« Reply #4 on: August 28, 2004, 01:17:54 PM »
The info I have is  for each panel -
Max Power: 3.2 Watts, 18.8 volts, and 170mA
Electrical ratings at 1000W/m Squared, AM 1.5, cell temp 25 C
Each panel has a one way diode and 12v male lighter end.
There will be three of these hooked into a 3 to 1 adapter 12 volt male lighter socket. From there, should I go to a charge controller, or straight to the battery?
I am doing this to increase the wattage to 9.6 watts
I am new at this, so sorry for any extra, or lack of, info and again, thanks in advance for any help
altpwr
« Last Edit: August 28, 2004, 01:17:54 PM by altpwr »
« Reply #5 on: August 28, 2004, 06:48:24 PM »
Since the panels have an integral diode, the three-way
cigarette-lightr adapter setup you describe should work
just fine.
There are two problems with overcharging a wet lead-acid battery:
The extra power goes into electrolyzing the water into gas (which
goes away) and into heating the battery (which can cause thermal
damage if the heat gets too great - and losing water also loses
cooling fluid that would otherwise help distribute the heat.)
But with only 3 * 0.17A = 0.51A in full sunlight, if you've got
a car-battery sized battery you definitely don't have to sweat
thermal runaway and molten lead or boiling water.  B-)
And with, say, 5 solar hours per day you only get about 2.5
amphours per day, so you'll be doing well to stay ahead of the
leakage.  If you check the water ever few months you don't have
to sweat it going dry.
So I wouldn't worry about a regulator.  Just check the water
from time to time.
If you have an 85 amphour deep-cycle battery and discharge it
down to 20 amphours (about 74% discharged) it will take it a month
or more of sunny days for the panels to bring it back to full
charge.  So undercharge, or sulfation from chronic undercharge,
might be more of an issue.
« Last Edit: August 28, 2004, 06:48:24 PM by Ungrounded Lightning Rod »
altpwr
« Reply #6 on: August 30, 2004, 11:44:25 AM »
Thanks for that info.  I take it you would recommend a wet battery opposed to a sealed battery?
Also, It sounds like I need to add a few more of these panels to make it even remotely usable - even though it is only for occasional usage.
Thanks again.
« Last Edit: August 30, 2004, 11:44:25 AM by altpwr »
