Author Topic: howdy ya'll  (Read 1083 times)
cstgmt
howdy ya'll
« on: October 11, 2004, 07:16:14 PM »
new to the board.  get my batteries from a UPS (battery backup) company that takes care of remote cell phone/radio station towers for ....free. have three pv's that i've purchased used (less than 3 years old each) and am getting new (still in the crates) 100 watt panels for $3 a watt.  all because i have no absolutely no money to spend on the lifestyle i've chosen.  am currently making battery cables from 4 awg and 3/8" copper tubing soldered on as lugs.  was looking into the scc3 charge controller as i'm currently just using a diode and would like a little better control on input voltage.  the scc3 was schematic'd out a little weak for me though on the full charge state dump load circuit.  any input would be appreciated (keeping in mind the absolutely zero dollar amount i can spend on the way). thanks!
« Last Edit: October 11, 2004, 07:16:14 PM by (unknown) »
Re: howdy ya'll
« Reply #1 on: October 11, 2004, 07:29:18 PM »
I'm no expert on this, but couldn't you use Forest's circuit to activate a relay, or supply the gate voltage to a string of parallel FET's and use them to handle the dump current?  keep having fun, Rich Hagen
« Last Edit: October 11, 2004, 07:29:18 PM by richhagen »
Opera House
Re: howdy ya'll
« Reply #2 on: October 12, 2004, 07:04:03 AM »
I suspect you have a lot more battery than solar panel.  Charge controllers are a waste unless you use a switching regulator to operate the panel at the maximum power point.  Unless you abandon the site for weeks, there is little chance of overcharging.  Currently, I only use an undervoltage monitor to shut off loads.  I am building a maximum point switching regulator for increased output from the panels and so I can operate panels at 24V and convert down to 12V.  The switching losses are more than made up by the savings in resistance losses since the panels are some didtance.
« Last Edit: October 12, 2004, 07:04:03 AM by Opera House »
hvirtane
    • About Solar Cooking
Re: howdy ya'll
« Reply #3 on: October 12, 2004, 10:55:04 AM »
I think that you should approximately
calculate the Ah of the batteries and the
power of your solar panels and
then also estimate how much you are using
the power. It depends on such things,
if you will need any charge controllers at all.
You might also check (with a volt meter)
sometimes the real condition of the
batteries, before making the decisions,
which kind of controllers to purchase.
« Last Edit: October 12, 2004, 10:55:04 AM by hvirtane »
