Author Topic: Battery voltage  (Read 1605 times)
jumpingjackflatch
Battery voltage
« on: December 23, 2004, 04:57:10 AM »
I was wondering, I have a battery voltage chart that translates battery voltage to percent of charge remaining. I have six 12 volt AGM batteries wired series/parallel
for 24 volts@100A/H. The resting voltage varies from 25.5 volts to 26.10 volts.
My chart says 25.40 volts is 100% charged. Is there a different chart that applies to AGM batteries, or is the only real way of tracking battery state-of-charge is by using an amp-hour meter?
Randie
« Last Edit: December 23, 2004, 04:57:10 AM by (unknown) »
iFred
Re: Battery voltage
« Reply #1 on: December 22, 2004, 10:27:02 PM »
« Last Edit: December 22, 2004, 10:27:02 PM by iFred »
Re: Battery voltage
« Reply #2 on: December 23, 2004, 05:05:40 AM »
  I liked that windsun link thing too except for that little menu box that followed down as I scrolled ....( yeah that's me picky picky!..LOL)
Merry Christmas!
             ( :>) Norm.
« Last Edit: December 23, 2004, 05:05:40 AM by Norm »
troy
Re: Battery voltage
« Reply #3 on: December 24, 2004, 12:54:44 PM »
Charts can be helpful, but keep this in mind:
  1.  The chart generally applies to one bat. temperature.
  2.  Many charts assume the battery is being neither charged, nor discharged (like for an hour or more, nothing in, nothing out).  Or, they will give you two sets of graphs, one for charge curves at different rates of charge, ditto for discharge curves.
  3.  The chart assumes your battery pack is brand new.  An old tired pack will not follow those charge/discharge curves like a new one.
You can also check electrolyte density, which tends to be a bit more reliable, especially if you use a good hygrometer.
Overall, the best method is probably an accumulating amphour meter like the trimetric.  It it not perfect, but it's very very good.
Good luck, have fun, play safe!
troy
« Last Edit: December 24, 2004, 12:54:44 PM by troy »
