I kinda just figure the batteries self discharge a certain amount, find that amount and have more charging capacity that that and they stay fully charged. Now figure what your gonna use and that's how much more charging capacity you need.
So if 1890amps hrs discharges 1% per day I would need 19 amps per day charging to keep it full charged. Now they should last forever, but their not doing me any good if I don't use them. So if I need to get 200 amps a day out I need 200 amps charging per day +19amps for self discharge.
If I only plan to use them once per week (like saturday) and only use 200amps that day, I need 200amps/7day = 26.8 amps charging per day to keep them full + the 19amps they self discharge.
And at 200amps out of a 1890amp bank I am drawing only around 10% of the bank so they should stay healthy.
Probably not the correct way to figure things, but it's my general easy way to geusstimate something.
I think I would go with cheaper smaller batts myself though as others mentioned. Things go wrong, I'd rather pull out 1 or 2 12V or 6V batts if I had to and still have power than pull out 1 2V and lose everything. Bad things do happen randomly.
For instance today I was stuck at the rock house I rented for about 3 hours with a dead battery on my truck. I could have easily pulled 1 12V battery to run my truck and kept the system up at the same time. Or I could have pulled 2 6V trojans and jump started the truck while still keeping the system up on the rest. (if I had everything set up, I could have connected the battery charger, but that was at home)
Personally I didn't care to go to that trouble and took a nap instead and jump started it off the wifes car when she got there.
Sometimes it's good to think about such things when dealing with remote locations
I didn't have a battery charger with me, had I needed to go somewhere right then I could have pulled one battery to get the truck started. For my only bank in a remote location I dought I personnally would go less than 6V batteries.
