Mlt, no one's here to make fun of you, your right. Solar cells hate heat, but they get in the high 100s, so 80-100F is a little low.
Stynus, it would work, but yes it would kill the cell almost instantly probably. If you could figure out a way to keep it under 200 degrees, it should work, at least a little bit.
They have something called a concentrator cell for this type of thing, which is built into a heatsink that you pump liquid through to cool it.
