I dl a .pdf file the other day claiming to detail how to make a cost efficient solar cell at home. I've been studying the file and it details 3 ways to make a solar cell, but the most interesting one doesn't have much detail to it. I have read and re-read it and took notes and came up with the following instructions to make the cell:
Ingredients
cadmium sulphide in powder forn (or thick liquid or ink form)
Cadmium chloride powder or liquid
propylene glycol liquid form
carbon powder (wood ash will work apparently)
cadmium
tellurium
use the propylene glycol to mix the powders into a pasty ink
Set up to silkscreen onto glass. Best to use a small area like an 8"x10" to begin with. Use yellow 200 mesh screen for your silkscreen printing and make sure that your frame is secured well to prevent drift.
Layer 1: clear glass
Layer 2: electrical insulation n-type CdS (cadmium sulphide)layer=negative
Apply 3 layers of Layer 2. Allow to air dry between applications, then bake at 600C(1112F) for 3 to 5 minutes (best done outdoors in a grill due to toxic fumes)
Layer 3: p-type CdTe (Cadmium Tellurium)layer - equal parts Cd and Te with the addition of CdCl2 (Cadmium Chloride)and propylene glycol, bake at 600C(1112F) for 3 to 5 minutes
Layer 4: a current collecting carbon electrode layer - silver & indium mixed to paste-apply a carbon layer prepared by kneading carbon powder with a viscous agent made of a solution of a resin in an organic solvent
Layer 5: an AgIn electrode positive terminal
OK, I'm not a chemist nor am I an electrician. Does ANYBODY have enough working knowledge to tell me if this might work? Because if it will, it looks like it might be possible to produce solar cells cheaply, I would like to experiment, but it would take an initial investment of around $200 to $250 for the chemicals and misc. parts I'd need and would like somebody's expert opinion before I go there. Any input would be welcome. Thanks.
