Author Topic: Grid Tie inverters  (Read 1038 times)
gogreen
Grid Tie inverters
« on: December 11, 2006, 07:51:10 PM »
I am looking for grid tie inverters that are suitable for 1Kw (8 x (12v) 125 watt panels). I am little confused about voltage input for these inverters. Most I have looked at have very high voltage input. How does this translate for the type of panels selected for a small grid tie system. Do I need 24v or 12v panels? Are there grid tie inverters with low voltage input. Any help with this would be appreciated.
Thanks, Paul
« Last Edit: December 11, 2006, 07:51:10 PM by (unknown) »
dbcollen
Re: Grid Tie inverters
« Reply #1 on: December 11, 2006, 02:04:22 PM »
There are several low voltage grid tie inverters available from Xantrex and Outback,
they require a battery bank. I believe SMA (Sunny Boy) has a few inverters for direct intertie as does Fronius (IG). Your 8 12 volt panels all in series should have an open circuit voltage of 168-175 volts and a max power voltage of 135-140 volts.
Also the advantage of high voltage series strings is smaller wires AND less losses.
Dustin
« Last Edit: December 11, 2006, 02:04:22 PM by dbcollen »
loobosh
« Reply #2 on: December 11, 2006, 09:08:08 PM »
hi
I have the beacon power m5 inverter it is a 48 volt it has battery backup which has been great in florida with all the hurricaines it is pricey about 4850 is the cheapest i have seen it, but well worth the money you can add more panels later it works with 4 panels up to 6000 watts.
« Last Edit: December 11, 2006, 09:08:08 PM by loobosh »
dastardlydan
« Reply #3 on: December 16, 2006, 03:29:52 PM »
LOOBOSH:
Where bout in Florida , I am just south of Tampa
Little town of Riverview .
Send a E mail dastardlydan1@verizon.net
« Last Edit: December 16, 2006, 03:29:52 PM by dastardlydan »
