hi there
yes you can use a linear actuator to control elevation throughout the year..
in my setup
http://www.redrok.com/led3xassm.htm#cross
i'm using a H-H mount and a redrok tracker for East-West tracking through the day, and a standard linear actuator for seasonal elevation adjustment on a manual switch.
i would highly recomend redroks LED3 tracker, its well worth the $38, especially in winter, ive gained almost 50% aditional output by tracking the sun during the day, and as you say the linear elevation control makes it really easy to adjust during the year, i'm currently spending about 2 minutes every few months watching the charge meter and adjusting the elevation via the actuator, i have a douple pole, double throw switch with a N.O. resting point to control the actuator.
the H-H motor is completely automated via the LED3 tracker, and only consumes about 5W a day.
also Duane @ redrok is very helpful and honest if you think about that route.hope this helps
satman
