Author Topic: Urban stealth system  (Read 1012 times)
GeeMac
« on: October 16, 2007, 12:41:58 AM »
To you country folk this is probably laughable, but it's beginning to work for me.
Here are the solar panels I have managed to acquire so far. Yesterday I managed to
get 4 of them tilted straight at the sun. I'll do the fifth one tomorrow. Note the use of some smaller panels on either side of the chimney. The are there to catch the rising and setting sun and are wired in parallel to get as much amperage as I can out of them.
Below is my first PVC windmill. It's on a PVC 12 foot pole and catches pretty good wind and furls nicely
On the chimney top is my experimental mill.
I also have a 1750 watt inverter and 5 twelve volt deep cycle marine batteries.
I'll post more for you to see as I add more
« Last Edit: October 16, 2007, 12:41:58 AM by (unknown) »
dudevato
Re: Urban stealth system
« Reply #1 on: October 15, 2007, 08:57:50 PM »
Nice looking operation.  It looks like you live in a pretty area.
« Last Edit: October 15, 2007, 08:57:50 PM by dudevato »
gotwind2
  • ben[at]gotwind.org
« Reply #2 on: October 16, 2007, 02:57:52 PM »
GeeMac.
You have contracted the addictive R.E. bug - It is very contagious around this forum I believe :)
I'm not sure if 'stealth' and wind power in particular go hand in hand though...
You've certainly made a good start. I would be keen to see your furling system on your wind generator. Is it of the standard 'gravity' method?
Pictures always help
Ben.
« Last Edit: October 16, 2007, 02:57:52 PM by gotwind2 »
« Reply #3 on: October 21, 2007, 03:54:30 AM »
That pvc pole will not take much abuse but I've had good luck setting them in a square concrete pad and filling with small aggregate concrete use some Emt conduit and 1/2 rebar inside You may have to up the size of your pipe to 4" . Works good though I guy it for safety as well but it's very rigid.
« Last Edit: October 21, 2007, 03:54:30 AM by tecker »
