I am looking at the 220VAC motor and wondering if that can be upgraded to a more RE friendly motor. Since you are grid tied do you have a figure for the present grid contribution on motor start up? Have you recorded the true amperage - voltage drop when the motor starts? Is this motor a crude Chinese clone bundled with press or is it a discrete component easily swapped out? Can motor be started free-wheeling with minimum drag or is it locked into turning screw drive from the beginning?
As I read it now we must start using the exact motor name plate data ie: frame style to allow estimating the ideal starting surge current but 5 or 7 times running amperage for startup surge will be a pricey retrofit for sure. (your 6000w figure equals 27~amps @ 220V)
Forgive me this, I am having a hard time with 10,000 watts solar as the system voltages must be high, 450VDC or more. Having a dedicated panel for daylight hours local usage tap into the current grid-tie solar feed circuits is going to be an irritation for every approval authority in your region, if they know about it.
A pair of the Xantrex XW-6048 6000w inverters could conceivably throw 24,000 watts surge out, they claim 104 amps surge for 7 seconds per unit but the reserve may not be there from PV generated power where from grid it would try and brown out everyone on your grid circuit, town, county...
Using the Outback FlexMax charger set for 60V output gives 4800 watts MPPT feed into a single XW-6048 if you can stay under their inverter 64V maximum input and so not need batteries while the sunshines - but rewiring to have alternate taps for 12 or 18 PV strings to feed the FlexMax to stay under 140V and stay within inspection code may mean a pardon from the Governor or something : )
