I would suggest leaving out "Blocking" diodes, anywhere in the system.
Some people argue the higher voltage panels will back feed the lower voltage panels,
but I don't believe it happens in this context.
There could be an argument for "Bypass" diodes, if some cells will be shaded in times of strong sun.
I would be more inclined to believe they will help a 48V input and 12V output, than 48V input and 24V output.
Pretty good chance 24V PVs of that size have bypass diodes installed from the factory.
Something to keep in mind for several years:
If the output drops drastically, check the bypass diodes first. They seem to have a tendency of failing to short.
