Author Topic: batteries  (Read 1317 times)
ronsmith
batteries
« on: May 18, 2005, 01:32:27 PM »
I saw some lawnmower batteries at Lowes. Are these deep cycle or not. they come in two different cca's and run from 28.00 to about 36.oo. Can I use these to store power from my solar panels? Also couldn't find voltage on them.
« Last Edit: May 18, 2005, 01:32:27 PM by (unknown) »
CarlB
Re: batteries
« Reply #1 on: May 18, 2005, 08:53:21 AM »
By definition, a "starting" or "starter" battery is designed to supply large amounts of current for relatively brief periods of time. The CCA is "cold crank amps". A deep cyle battery is designed to supply small amounts of current for relatively long periods of time.
To answer your question: yes, you could use them to store power. BUT, there are much better choices.
Here is most everything you ever wanted to know about batteries:
http://www.google.com/search?hl=en&q=battery+faq&btnG=Google+Search
« Last Edit: May 18, 2005, 08:53:21 AM by CarlB »
