Author Topic: Cap's inline on Ametek?  (Read 1245 times)
coldspot
« on: December 19, 2005, 05:26:34 PM »
Hello all- HAPPY HOLIDAYS ALSO !!!
I'm still a newby so please bear with me, while doing research, (reading old posts here)!
I found this-
"Filter the outputs at the pole!! You will have higher output and less ripple and more consistant power. Causes less problems. That voltage seems great! Match the temprature as well. Caps run at different tempratures, find one that is sutible for the lowest temprature in winter conditions. The higher the farad randge on your cap the better. Also this will lessen the load on the generator durring high load conditions. Acts like a small battery that will feed a bigger one, but charges smaller one first before feeding big one, hence produces lesser load and higher consistant voltages."
So I should put a cap on each PM Gen to help it out ???
Motor Running Cap's ???
« Last Edit: December 19, 2005, 05:26:34 PM by (unknown) »
$0.02
Re: Cap's inline on Ametek?
« Reply #1 on: December 20, 2005, 06:02:33 AM »
The Ameteks common on this board are brushed DC PM gens. The output is fairly smooth DC. Caps won't help.
« Last Edit: December 20, 2005, 06:02:33 AM by ghurd »
coldspot
« Reply #2 on: December 21, 2005, 02:21:30 AM »
Cool, thats what I wanted to hear !!!
Back to the "off-set & furl".
Thank you
« Last Edit: December 21, 2005, 02:21:30 AM by coldspot »
$0.02
