Author Topic: Preheater?  (Read 1409 times)
Preheater?
« on: November 28, 2006, 12:03:35 AM »
Awhile back Finsawyer mentioned spinning a fan inside a tank with a rooftop vawt to preheat and that got me thinkin.
Why not use the incoming water pressure/flow to spin blades or some other restrictions inside a heat exchanger before the water heater. It could be made fairly long and use no power.Not sure what the gains would be.
 Seems feasible doesnt it.
 V......?:>/
« Last Edit: November 28, 2006, 12:03:35 AM by (unknown) »
Re: Preheater?
« Reply #1 on: November 27, 2006, 05:16:27 PM »
The heat comes from the power supplied - as flow rate times the pressure drop.  You'd get virtually no heat from it.
Further, you'd get the SAME heat whether you "spin a fan" or just let the incoming water lose some of its pressure through turbulence.  So why add a moving part (and trouble) for no gain?
The heat in the Finsawyer system comes from the power used to spin the fan against the water's friction.  You can shape your fan to generate a LOT of water friction - and consume a lot of power - to "waste" that power by turning it into a lot of heat.
« Last Edit: November 27, 2006, 05:16:27 PM by Ungrounded Lightning Rod »
Re: Preheater?
« Reply #2 on: November 27, 2006, 07:00:35 PM »
The supply line of the water heater comes in at 50degrees with lets say a 3/4in pipe thats alot of makeup.But what if we expanded that to 4in over a 10ft lenght with restrictions of some sort and then fed the heater.
 5 or even 10 degrees would really add up over time.
 I know im off base most of the time.Just Thoughts
 Thanks for the reply Rod
« Last Edit: November 27, 2006, 07:00:35 PM by vawtman »
Stonebrain
Re: Preheater?
« Reply #3 on: November 28, 2006, 03:04:05 AM »
To convert kinetic energy in heat directly you need
quite a huge 'paddlewheel'.
See my own experience
http://www.fieldlines.com/story/2006/11/7/202828/758
With a 15 liter 'paddlewheel'drum I didn't get
more then 6watt.
The energy in the waterflow is probably negligable and
anyhow you need to power a pump to make it flow.
cheers,
stonebrain
« Last Edit: November 28, 2006, 03:04:05 AM by Stonebrain »
Stonebrain
Re: Preheater?
« Reply #4 on: November 28, 2006, 03:11:15 AM »
This result was at 100-120 rpm maxi.
At higher rpm's the result might be a lot better.
« Last Edit: November 28, 2006, 03:11:15 AM by Stonebrain »
Re: Preheater?
« Reply #5 on: November 28, 2006, 04:53:01 PM »
Stonebrain i saw your posting with the Torkmaster COOL.
 Ive always wanted to spin a squirlcage fan in water with the turbine but havent tried it yet cause i cant come across a big enough unit.
 Thanks for the reply.
« Last Edit: November 28, 2006, 04:53:01 PM by vawtman »
