Hey all,
We talked about this before, and many people say store bought is not that expensive so why bother making cable ends ourselfs. But yes store bought is expensive when you not many of them!
Well here is a point of interest not mentioned in the past that I know of.
I left 3 walmart deepcycles sit for awhile, did not need them then or the 5K inverter.
They went dead from sitting and inverter draw over time, was charged once or twice perhaps, this sat for about a year I geuss since connected, used a bit but mostly sitting.
Yesterday I went to the old trailer, fixing up a shop and gonna live in it part time, so I check the batteries right. Gonna be offgrid mostley so I will need them.
- deep cycles in parralel, 6 posts, the ONLY post that did not have a giant large coating of goop was the only post that had only my homemade cable end on it.
- posts had that crusty cystal like build up, major large formation I could not even see the wing nuts hardly! Other post had a nasty gooey brown goop. My homemade cable end is tarnished a bit but otherwise nice and clean, nothing on the post at all.
I will try to post the pictures I took later, camera not here right now.
My cable end was just a piece of cleaned copper tubing, one end hammered flat, hole drilled for the bolt, rounded with a file to prevent a sharp corner. Hammered down and set tight onto the cable. No corrosion!
The posts with corrosion were Walmart bought ends (more costly and the worst), large cables with ends that came with my inverter, some auto cables with factory ends like would be used on a soloniod.
I takes me about 1" of scrap copper tubing and less than 3 minutes to make an end, total cost about 5 cents, you can bet I will make my own and never buy another 50cent to $1 end again! I only bought a few anyway when I first started needig them. As for those already on cables, I will be cutting most of those off and putting my own on!
I have better things to do than clean correded terminals any more than I have to.
