Author Topic: good or bad battery bank  (Read 2368 times)
tlp
« on: November 21, 2009, 09:32:50 AM »
I have 20 24volt sealed lead acid batterys. in series parell 48volt. 10ft.48volt turbine built from homebrew book.the batteries are 42 amp hour. Need comments.  thanks tlp
« Last Edit: November 21, 2009, 09:32:50 AM by (unknown) »
Re: good or bad battery bank
« Reply #1 on: November 21, 2009, 01:51:24 PM »
Are the batteries new or used, what brand/model? Are they agm or gel?
What do you want to run from the batteries? 48 volt inverters are not common.
Using a controller to down convert to 12v would give you more appliance choices and allow your turbine to charge the batteries even on a calmer day.
« Last Edit: November 21, 2009, 01:51:24 PM by dnix71 »
rossw
« Reply #2 on: November 22, 2009, 02:15:31 AM »
Disagree completely! There are a good many inverters that are 48V, and as you move up in the world, there are a good many that ere 48V or more ONLY.
Almost all telco equipment in the world is 48V.
If you'd said "Small, cheap 48V inverters are not common" I'd have agreed....
« Last Edit: November 22, 2009, 02:15:31 AM by rossw »
tlp
« Reply #3 on: November 22, 2009, 06:02:16 AM »
Batterys are Concorde Platinum series value regulated sealed lead acid non-spillable aircraft batterys. About 10.5 in. sq.and 88lbs.each
« Last Edit: November 22, 2009, 06:02:16 AM by tlp »
« Reply #4 on: November 22, 2009, 12:04:54 PM »
"not as common"
48 volt is much more efficient. Ames has one now that is the same price as it's 24v counterpart, but I have an Ames and wouldn't recommend it at all.
It doesn't handle overloads correctly. The voltage sags, but it doesn't trip offline.
The frequency is also off and can't be changed because it's crystal controlled.
Aviation batteries and telco equipment doesn't strike me as "home brew" If you have industrial grade equipment, why play with a homemade turbine? Valve regulated AGM's require TLC. If the batteries were flooded deep cycle, then that would be an ideal setup.
Converting down to 12v or 24v would be better/safer than just hooking it up to the turbine directly, unless the wind blows moderately steady all the time.
He needs a fail-safe dump load, too, without a self-regulating turbine.
If his batteries are new he has 20kwh of bank. That's going to hard to keep charged, again, unless the wind blows a lot, or he has a big generator to top it off during a calm couple of days.
If his batteries aren't new, then he needs to do a load test so he knows how far down a safe discharge is, and to plan for a proper recharge.
« Last Edit: November 22, 2009, 12:04:54 PM by dnix71 »
hayfarmer
« Reply #5 on: December 29, 2009, 05:27:48 PM »
heres a pic of magnum MS AE4844 48 volt inverter /w battery charger.
You can put charger instandby mode when charging by wind or solar etc or turn it on if nothing is working that day :( .I like this type cause it transfers it self in power outages.
http://s706.photobucket.com/albums/ww62/ericheise/
« Last Edit: December 29, 2009, 05:27:48 PM by hayfarmer »
