Author Topic: Another question for Zubbly  (Read 973 times)
Otto
« on: August 14, 2007, 01:07:08 PM »
Zubbly, I have been busy cleaning up my basement which flooded, so the wind generator was on hold.  Today I spent sometime on the generator and was able to find the "Y" connection and traced which wires were 7,8,and 9.  The connection seems to be a crimp connection and not soldered. The wire is copper colored but appears to be aluminum after scraping away the outer coating.  The coil spans appear to be the 8-10-12 set up.  To add the addittional leads can I use crimp connectors with heat shrink tubing over it?  Do the addittional leads need to be aluminum wire?  Do I need to re-lace and re-varnish the wires?
Thank you,
Otto
« Last Edit: August 14, 2007, 01:07:08 PM by (unknown) »
