Author Topic: IRON FILINGS in Epoxy for stator?  (Read 1167 times)
xymox
« on: February 16, 2009, 04:25:32 PM »
Was thinking of a way to make a stator without laminates. This would be used in a 3 phase single rotor alternator, much like an induction motor conversion that I see here on the site.
I was considering using expoxy and mix with a large amount of iron filings to surround my coils and by doing so would surround the coils with the iron creating an efficient flux path. In effect I would be pouring on the epoxy/iron mix directly on the coils/stator and rotating at high speed to evenly distribute the mix.
Any problems with this?
Been discussed at length. If you check his history he is trying to put together some product therefore his laziness not searching should not be rewarded by allowing him to troll for suckers to do his research. One of the fuzzy areas here is it OK or is it not? I say not.TW.
« Last Edit: February 16, 2009, 04:25:32 PM by (unknown) »
