Author Topic: Lets do the twist!  (Read 1081 times)
gizmo
    • The Back Shed
Lets do the twist!
« on: June 13, 2004, 05:55:27 AM »
I have a testing windmill with a set of 3 plywood blades. Each blade is approx 1 meter long and 18mm thick. Front is flat, back has a basic aerofoil shape. The blades were angled at approx 15 degrees.
These blades have been in use for over 12 months and survived a tower fall 9 months ago.
I tilted the windmill down to try a new lighter steel propeller hub that I lasercut a few days ago. Recently I had read an article about blade twist and the effects of stalling blade tips at high speed, so I decided to fire up the power plane and reshape the blades to provide 5 degrees of twist at the tips while keeping the original 15 degrees at the centers.
A quick coat of paint and the windmill was back up in the air. Straight away I noticed a dramatic increase in speed, and less noise. Giving the blades a bit of twist has made a big difference in performance.
My next set of blades will definately have the correct twist angles, the gains are worth the extra work involved.
I've taken some photos of the new propeller hub, will put on my website in the next few days.
http://www.thebackshed.com
Glenn
« Last Edit: June 13, 2004, 05:55:27 AM by (unknown) »
hvirtane
    • About Solar Cooking
Re: Lets do the twist!
« Reply #1 on: June 13, 2004, 02:40:36 PM »
I looked at your site.
Really nice pictures and descriptions
how to make the machine
you have got there.
Thank you a lot for sharing all
you constructions and the working
methods of yours.
I think that your original blades
without twist were with quite high
pitch angle. Did you try with
7 - 8 degrees?
However I think that with twisted
blades the result will be better.
Have you tried with that F & P
generator to put two of them
on the same axle?
You might easily build a
machine with 1 kW power if
you put three of them...
« Last Edit: June 13, 2004, 02:40:36 PM by hvirtane »
