Author Topic: Appropriate bearings?  (Read 1191 times)
Jon Miller
    • Otherpower UK
« on: July 24, 2004, 10:05:20 AM »
The pic below is of a small trailers wheels and bearings.
I plane to use one end for the yaw bearings and the other for a PM ALT.
I would like to now if cutting the shaft in the middle is the best thing to do with it considering my plans or whether it should be cut 1/3 to 2/3?
« Last Edit: July 24, 2004, 10:05:20 AM by (unknown) »
MelTx
Re: Appropriate bearings?
« Reply #1 on: July 24, 2004, 11:25:09 AM »
    Hello. If in doubt cut it in half you can always cut off some more.Thats a great idea, when I saw your post I grabed my pencil and went to drawing, to see what might be possible..... Thanks for the inspiration.
                        Franknbuger
« Last Edit: July 24, 2004, 11:25:09 AM by MelTx »
RobC
« Reply #2 on: July 24, 2004, 02:49:47 PM »
Hi Jon what I like to do is make sure replacment bearings and seals are readily avalible. I would suggest you take the bearings numbers to a local supplier and check. You don't want to spend money on a project if you can't replace the bearings later.
« Last Edit: July 24, 2004, 02:49:47 PM by RobC »
RobC
« Reply #3 on: July 24, 2004, 02:54:40 PM »
They should work all right for a small project if they are in good shape. Good luck RobC
« Last Edit: July 24, 2004, 02:54:40 PM by RobC »
BruceDownunder
« Reply #4 on: July 24, 2004, 05:11:16 PM »
Bloody beautifull grass !! don't get any muck on it ! The bearings are great ,just clean them up on someone else's grass.
I actually used a hyundi front wheel drive wheel assembly .Cut down and trow all the unnessary steel away ,you then have a drive shaft to connect to whatever.
Bruce
« Last Edit: July 24, 2004, 05:11:16 PM by BruceDownunder »
« Reply #5 on: July 27, 2004, 02:56:12 AM »
   Looks like the hubs have been left to the elements for a while the wheel bearings
 will be a question look for machining marks on the spindle and if they are not hammered  go for it you can usually find a bearing house that can match them up . Seals are a diferent mater . seals being a comman replacment item may have stocks from the epuip manufacturer .
« Last Edit: July 27, 2004, 02:56:12 AM by tecker »
