Author Topic: 3ph 1/2hp motor conversion , rewire ? or not  (Read 1934 times)
ibedonc
« on: July 28, 2004, 03:24:39 PM »
I have turned down the rotor on a 3ph 1/2hp a/c motor   to take 12 N and 12 S neo
like these http://www.rare-earth-magnets.com/SearchResult.aspx?CategoryID=21&KeyWords=Segment&All=True
Product ID:   NSN0025
Product ID:   NSN0026
they will be place 2 side by side and 12 (6 north x 6 south) around the rotor
this is a 230/460v motor , I really do not want to rewire it , unless it will not work
otherwise , I have not counted the poles yet , but they are a lot , I would say more then 20 , what is the best way to wire it up , I want low speed high voltage windgen
I got these motor for free and also have a 1hp that I may play with
Jerry you out there :)
« Last Edit: July 28, 2004, 03:24:39 PM by (unknown) »
Re: 3ph 1/2hp motor conversion , rewire ? or not
« Reply #1 on: July 28, 2004, 05:08:32 PM »
   If your thinking amps you gata think about 14 awg or more I'm shure I get some disagreement from those in the know . But to run cool and jack some amps you gata
have some mass to generate amps.
« Last Edit: July 28, 2004, 05:08:32 PM by tecker »
Electric Ed
« Reply #2 on: July 28, 2004, 06:23:13 PM »
I doubt if the stator winding has more than 20 poles, perhaps you mean coils, which is quite different.
A typical 3 phase winding would have 3 coils per pole per phase, for a total of 18 coils for a 2 pole winding, or 36 coils for a 4 pole winding.
Try to determine the coil span, in other words, how many slots are spanned by an individual coil.
The center-to-center distance between the rotor poles (magnets) should be the same as the coil span.
That size motor probably has the phase windings wye connected internally. Does the motor have 9 leads or 12?
Electric Ed
« Last Edit: July 28, 2004, 06:23:13 PM by Electric Ed »
ibedonc
« Reply #3 on: July 28, 2004, 11:43:34 PM »
Misunderstand poles , thinking the stator slots were poles
it is a AO Smith motor with 12 leads , 18 coils , coil spans 6 slots
since my magnets do not cover a coil span , could I put two norths side by side to cover it. they are wide enough then , that would give me 3 north poles and 3 south
if this would not be good enough then could rewire it 3 slots which the magnets cover fine , the only problem it is going to be a lot of work getting the old wire off , that
stator is in that housing good. if I do rewire , what do you suggest for turns
thanks
« Last Edit: July 28, 2004, 11:43:34 PM by ibedonc »
Victor
« Reply #4 on: July 29, 2004, 06:49:52 AM »
  "since my magnets do not cover a coil span , could I put two norths side by side to cover it. they are wide enough then , that would give me 3 north poles and 3 south"
 This sounds like it will work,but be prepared for cogging. The cogging will exist because of not having skew.
« Last Edit: July 29, 2004, 06:49:52 AM by Victor »
« Reply #5 on: July 29, 2004, 10:39:10 AM »
Space the magnets so the combined pole is about as wide as the combined stator poles surrounded by a single coil.
An easy way to figure out how many poles you need is to look at the rated line frequency and RPMs.  A two pole will be a bit less than 3600 RPM at 60 Hz, a four-poll a bit less than 1800 RPM, and so on.
Alternatively, count the coils:  On a typical three-phase you have (coils * 2 / 3) poles.  (You have half as many poles as coils in a phase, because each coil provides two runs of wire under the magnets, one front-to-back, one back-to-front, and is driven by two poles simultaneously.)
« Last Edit: July 29, 2004, 10:39:10 AM by Ungrounded Lightning Rod »
« Reply #6 on: July 29, 2004, 09:56:20 PM »
Hi ebedonc.
Sorry bout the delayed responce.  What will be the charging voltage when done?
If its 24v or higher I would not rewire at first. Try it as is. I use my 3 phase conversion this way. Wire the motor in its low volt scheam. Generally 208/240v as oposed to its 440v option.
« Last Edit: July 29, 2004, 09:56:20 PM by Jerry »
ibedonc
« Reply #7 on: July 30, 2004, 09:36:03 AM »
do you think 4 of your blades would be big enough for this one
do not know what the volts will be yet because I will not get my order of magnets
until monday , then I have to figure out how to connect this one up because it does not
have a wiring diagram on the motor
it has 12 wires , do you how I get to the wye common ?
« Last Edit: July 30, 2004, 09:36:03 AM by ibedonc »
ibedonc
« Reply #8 on: July 30, 2004, 10:09:14 AM »
this is the motor I have
http://www.aosmithmotors.com/pdf/catalogs/150/PAGE64.pdf
and this some good info on motors , it mite have answered my wiring question
http://www.aosmithmotors.com/pdf/brochures/bulletin3100/acdc.pdf
« Last Edit: July 30, 2004, 10:09:14 AM by ibedonc »
