Greeting fellow experimenters
I am a first time caller, long time listener. Fantastic board. I want to start out by saying that the last 3 mills that I have built used bicycle front forks and the supporting tube and ball bearings for both yaw and tail furling aplications. Small dia. frame tubing is used for generator mounting and larger frame tubing for tail booms. Even cheap bicycles use carbon steel, which is much stronger than electrical conduit.Theese components have held up well on 14' dia. mills. Another durable item that I like is a round tail made from the bottom of a plastic 55 gal. barrel.
I have made propellers carved from foam, conduit and plastic sails, built up with wood ribs and alum. skin, and cut diagonally from 55 gal. plastis barrels. My favorite is a wooden prop carved with a draw knife, a plane and a scraper. I have read a lot of posts where some one agonizes over carving their first wooden prop. My advice is to just dive in and start making shavings. And dont waste money on premium grade wood with out any knots. Sure knots are a weak area, just dont have any in the inner 1/3 near the hub. I have had props made of crappy lumber sustain storm winds without blowing up. But do take pains with balancing.
I have used tape drive motors, industrial dc motors and un modified induction motors wich are my favorite because of cheapness, no brush wear or drag, no cogging, and higher voltage output, which means cheaper, smaller copper conducter from the tower to the house.
Thanks for listening
