Author Topic: How many magnets versus coils  (Read 3433 times)
chewyms
« on: August 05, 2004, 09:58:43 PM »
  I have been doing some research on building a wind powered generator.
I've noticed that some have the exact number of magnets versus coils and some are not.
Is there any things that should or not be done for this.
I've always thought that the number of coils should match the number of magnets.
Thanks for any feed back.
« Last Edit: August 05, 2004, 09:58:43 PM by (unknown) »
Nando
Re: How many magnets versus coils
« Reply #1 on: August 05, 2004, 10:56:29 PM »
For wind mills there are two types of arrangements:
Equal magnets and coils; this case the generator has cogging that may require certain higher wind velocity to start operating
The second case where the magnets have a EVEN value and the coils are ODD (one less than the magnets pairs).
Like 24 magnets (12 pairs) and 22 coils (11 pairs) for minimum cogging effects which allow to start with low wind velocities.
The second case may give a distorted wave form that for battery charging does not affect the end result.
Regards
Nando
« Last Edit: August 05, 2004, 10:56:29 PM by Nando »
edy252
« Reply #2 on: August 06, 2004, 01:35:31 AM »
hi....
to connect ur coils in series or parallel (usual connection single phase) u need equal nubmers of coils and magnets.....while, for 3 phase, which is much better concerning battery charging, smooth starting, and less wire losses, u need a certain ratio between the number of the two.....
i do prefer 3 coils for 4 magnets
ex:
  1. COILS / 4 MAGS
  2. COILS / 8 MAGS
  3. COILS / 12 MAGS
AND SO ON
« Last Edit: August 06, 2004, 01:35:31 AM by edy252 »
DanB
    • otherpower.com
« Reply #3 on: August 06, 2004, 08:15:19 AM »
The comments regarding cogging and startup torque would only be true in this case if its a machine which has cores in the coils, or slotted laminates.  A single phase machine, same number of coils as magnets, will not cog otherwise, untill current is flowing - so no matter what number of coils you use, startup torque is not an issue if it has not cores in the coils, and/or no slotted laminates.  If its the "normal" dual rotor design... startup will always be a none issue no matter how many coils you run with.
If you run with same number of coils per magnet that'd be single phase.
Half the number of coils as magnets would also be single phase.
Single phase seems a bit simpler and there may be a bit more flexibility in how you can wire it up, - that's where the advantages end though.
3 phase will run with much less vibration once current starts to flow.  It will make better use of all the conductors both inside, and outside the alternator, and in the end you'll squeeze a bit more power from your machine if you wind it up 3 phase.  A simple and effective formula is 3 coils/4 magnets.  There are some other interesting winding ideas from windstuffnow that may be more effective for 3 phase output.
Do a search on this board if you want gobs of ideas and opinions and a good way to get even more confused!! ;-)
« Last Edit: August 06, 2004, 08:15:19 AM by DanB »
devoncloud
« Reply #4 on: August 06, 2004, 09:04:16 PM »
If you will look at windstuffnow's postings, you will also see that you can make three times the amount of coils than you have magnets.  if you have twelve magnets, you can have 36 coils.  the coils simply overlap each other a little.  Doing it this way puts much more copper under each magnet causing you to get much more power from your unit than if you simply made twelve coils for twelve magnets or whatever.
So I guess the answer to your question is that you have a good number of choices.  It all depends on how much research you want to do.  Everything that you will need is on this website just about.
Devon
« Last Edit: August 06, 2004, 09:04:16 PM by devoncloud »
devoncloud
« Reply #5 on: August 06, 2004, 09:05:49 PM »
oh ya, making a bunch more coils like windstuff now also prevents the cogging affect in single magnet rotor designs as each magnet is always under a load.
Devon
« Last Edit: August 06, 2004, 09:05:49 PM by devoncloud »
hvirtane
    • About Solar Cooking
« Reply #6 on: August 11, 2004, 04:38:04 PM »
Some of my design ideas
you can see in my diary:
http://www.fieldlines.com/story/2004/6/2/163021/1860
« Last Edit: August 11, 2004, 04:38:04 PM by hvirtane »
