When a fluid, such as air, flows around an object, such as a nose cone, it's speed increases. This increase in speed drops off with distance from the object. Because of the speed increase, the power available in the air stream is greater. In fact, for a hemisphere, the power available actually is greater for the air hitting the blades with the hemisphere (nose cone) than it is in the case of the entire cross section of the blade assembly without the nose cone. If the nose cone has a radius of half the diameter of the windmill a maximum power gain of 22% is attained. At least that's what theory states. Of course, to tap this power increase the pitch profile of the blades must be different. If you think this effect is a crock and you live in an area of large snowfall, I suggest you go out and check out the depression that forms at the base of a tree or utility pole due to the wind. Think about it. There is definitely a concentration of energy taking place.
