Author Topic: Magnetwire - what type  (Read 879 times)
Reno
« on: November 23, 2004, 05:29:39 PM »
I do not have readily available sources for magnet wire and being in Canada does not make it possible to order from the guys here at otherpower. So here is a webpage with different ytpes of magnet wire could some one be so kind as to point out the one to buy. I would want to choose some exotic wire that costs a fortune.
thanks
http://www.electro-wind.com/Product/magwire.htm
« Last Edit: November 23, 2004, 05:29:39 PM by (unknown) »
picmacmillan
Re: Magnetwire - what type
« Reply #1 on: November 23, 2004, 06:13:42 PM »
hi reno.....i can help...i just got a roll from them today..if you order today it will be in tomorrow.....the size of wire depends on the machine you want to build but what i have been told is to buy "#14 magnet wire" the "red" stuff, and they will know what to give you.......dan on here recommends #11 but the place you want to order from only has that in an 80 lb roll so i don't think you want that...the other stuff is about 10 lbs.what dan does is uses two wires of # 14 together to make a coil and that will emmulate a #11 wire. He has had good success with it and if you read his posts on 10,12 and 14" wind genny's you can go by that...on the top of my roll it says ALC^TEL..below that it says 14 then HMT PA-200  MW 35C......hope that helps....have a good one...pickster
« Last Edit: November 23, 2004, 06:13:42 PM by picmacmillan »
Reno
« Reply #2 on: November 23, 2004, 08:28:44 PM »
Thanks pickster. 80 lbs that might get me one coil. Ok to dream.
10 lbs sound good should leave me room to do some test coils.
« Last Edit: November 23, 2004, 08:28:44 PM by Reno »
picmacmillan
« Reply #3 on: November 24, 2004, 06:46:30 AM »
last time i got a roll same as i suggested only of #18 and i got 13 coils with 200 rounds in each...don't use this amount of rounds it's way to many...i was just learning.....and my resistance was too high  1 ohm each coil..take care ...pickster
« Last Edit: November 24, 2004, 06:46:30 AM by picmacmillan »
