I have an idea that might reduce the problem of "cogging" as it applies to low speed operation of a wind generator, by making startup easier in light winds. I have been meaning to post it here, but I haven't even been able to figure out how to post a photo, let alone draw and post a diagram that would illustrate my idea, so I am going to try to describe it with words alone. It's a really simple idea, so the thing just may be within my power to get across this way. I would not be surprised to learn that it was invented in 1912, either, but here goes.
I think the simplest example would be a single-rotor disc alternator. How about allowing the armature shaft to slip "forward and back" so as to vary the airgap? A simple spring would hold the gap at the widest position until there was a sufficient thrust load from the wind pushing on the blades. As the wind speed increased, so would the thrust loading, and of course the airgap would get smaller and increase the output of the alternator. The mechanism for this needn't be complicated or bulky. A coil spring would fit over the shaft, pushing against the inner race of one of the bearings, while a simple set collar or other sleeve arrangement could provide a positive stop at the "maximum flux" position, keeping a safe airgap no matter what the wind conditions might be. It would take some fiddling with spring tension, and some effective way to keep the sliding shaft from getting stuck, but that's minor. Of course one could dream up a system with a servo controlled by an IC device, which could be adjusted by the user, but the simplicity of a spring appeals to me.
I suspect the same idea could be used with a radial flux alternator (converted motor type), but it seems like it would be more complicated and I don't have enough of a handle on all the factors involved to make an intelligent prediction. Of course the airgap would not vary in that situation, only the alignment of the magnets with the coils. It seems that it would be very hard to implement on any machine that used a hub from a car, since those parts are of course designed to keep the car wheel on the straight and narrow. Too bad, too, 'cause those machines are way cool. Anyway, that's my idea, and if I ever move to a place where a windmill is feasible, maybe I'll build a generator and try it out myself. I live in the middle of an old part of town, on a 75 x 125 foot lot. Oh well.
What a great resource this is! I've been around here since the early days of the old board, under various names that have passwords I can never recall, and which are associated with email addresses that are long gone. I have learned a great deal, had many a good chuckle, and have been amazed by the inventiveness of this crowd. Thanks, All!
Zack Reuter
Grand Junction, Colorado
