All of the big gens I have seen in fotos look like one can fall in any direction and not hit any of the other towers, which is what you mentioned.
It can also throw a blade and have a low probability of the next one over. (Imagine the domino effect if that one then throws ITS blades and gets the NEXT one, all down the line...)
For smaller mills thrown blades will have more reach as a percentage of size than with larger ones. Speed is the same for a given TSR and thrown distance is mostly proportional to speed so it doesn't change a lot with the mill's scale.
In more detail: The launch altitude DOES change, so a blade thrown downward at an angle will go farther for a high mill than a low one. But if a blade is thrown upward at an angle its trajectory from launch to return to the mill's height will be the same regardless of mill size, i.e. it will NOT scale. Only the part of the path down from there will give the higher mill more reach than the lower one.
(That's all neglecting differences in air friction and blade density, of course.)
I suppose if one of my gens falls I need to try to avoid hitting the wires
Throwing a blade or a detached tail into them would also get the power coop upset. B-)
