Author Topic: Tilt back furl  (Read 2349 times)
harrie
Tilt back furl
« on: July 03, 2005, 03:58:12 AM »
Hi guys, this is the first time that I have tried to submit a posting with pictures, so hope everything works ok. The following pictures are of a 3 phase duel rotor, made from the front wheel assy. of a 1989 ford two wheel drive. I have machined both ends of the hub, to receive two flanges that were also machined, that have the bolt pattern of the two rotors that are from the front of a 1999,ford 4 wheel drive. The magnets are the 2" X 1/2" discs, 12 on each rotor. the stator is of 9 coils using 36 turns of double strands of # 15 magnet wire. The props are made from basswood, at a 12 foot Dia. The furling system is made using a double acting small hyd. cylinder, with a 1/4" hose runing from one  port to the other. this acts as a shock absorber by leting the flud flow back and forth between ports. I have also added a spring on each side of the cylinder, so as to be able to adjust the time I want the mill to furl. I have it set to furl a 60 amps DC. I have to say, that it works flawless. It tilts back and forth very smoothly, with no slaming or swinging back and forth. The tail probley dose not need to be so big, but I wanted the weight to be equal over the swing bering, and I also beleive that it helps to keep it into the wind while it is furled. I have it mounted on a 60 foot tower, and it seems to always put out some power. It will do 60 amps in 20 mile wind. I couldnt be more happy with it. My knowage in electronics is very limited, so I thank all you guys on this site, for explaining everything over and over for us that are trying to learn, and I need to give special thanks to Dan B. for all the help he has given me in the past. I have alot more pictures of the construction of this mill, if anyone is interested. If so, I will send them your way.Thanks again for helping me get into this great project.
Harrie
« Last Edit: July 03, 2005, 03:58:12 AM by (unknown) »
Re: Tilt back furl
« Reply #1 on: July 02, 2005, 10:40:51 PM »
Very cool.
Can't make it out. What is the name on the tail?
« Last Edit: July 02, 2005, 10:40:51 PM by ghurd »
Seth
Re: Tilt back furl
« Reply #2 on: July 03, 2005, 12:34:28 AM »
i think it says "Stump Power"
« Last Edit: July 03, 2005, 12:34:28 AM by Seth »
drdongle
Re: Tilt back furl
« Reply #3 on: July 03, 2005, 07:28:06 AM »
Very nice, can you share some more mechanical details? close up photos, and so forth?
« Last Edit: July 03, 2005, 07:28:06 AM by drdongle »
harrie
Re: Tilt back furl
« Reply #4 on: July 03, 2005, 07:57:12 AM »
the name on the tail is Sumo Power, which is my last name. Just being funny!!!
« Last Edit: July 03, 2005, 07:57:12 AM by harrie »
harrie
Re: Tilt back furl
« Reply #5 on: July 03, 2005, 08:02:09 AM »
Yes, I will try and get the best pictures rounded up and get them to you. Im a little slow on this new fangled gadjet, so it may take awhile.
« Last Edit: July 03, 2005, 08:02:09 AM by harrie »
Shadow
Re: Tilt back furl
« Reply #6 on: July 03, 2005, 10:11:33 AM »
Very Nice! The old Parris-Dunn 12 volt Windchargers used tilt back configuration. Theirs used spring action.I always thought it was a good idea. You did a very nice job on everything!
« Last Edit: July 03, 2005, 10:11:33 AM by Shadow »
Devo
Re: Tilt back furl
« Reply #7 on: July 03, 2005, 05:27:48 PM »
If you could really detail the furling that would be great , I wanted to try a tilt back furl but I was worried about the genny head slamming back but it sounds like you have it worked out good
Nice looking Genny
Devo
« Last Edit: July 03, 2005, 05:27:48 PM by Devo »
DanB
    • otherpower.com
Re: Tilt back furl
« Reply #8 on: July 04, 2005, 07:37:30 AM »
Looks quite nice!  Be fun to hear more about it in the future.
What's the tail made of?  I've had fairly bad luck with sheet metal tails though Im sure it can be made to work.
« Last Edit: July 04, 2005, 07:37:30 AM by DanB »
jimpep
Re: Tilt back furl
« Reply #9 on: July 04, 2005, 02:08:06 PM »
Great work Harrie: It looks like your hard work paid off.
Jim
« Last Edit: July 04, 2005, 02:08:06 PM by jimpep »
mjrleap
Re: Tilt back furl
« Reply #10 on: July 14, 2006, 05:15:51 AM »
I was searching "basswood" and found this post. Basswood is one of the options I've been thinking about using for a 15 foot machine. Have you had good results using the basswood for blades. I see from the picture the blades are painted. What kind of paint did you use?
This forum is really a cool thing!
Mike
« Last Edit: July 14, 2006, 05:15:51 AM by mjrleap »
