I am new to the board but readers may find some of my experimental kit interesting.
I am focussing my attention on wind power and thought you might be interested in what I am doing. I have home designed a universal type of rotor hub assembly so that I can begin to play around with a windmill unit. I have attached some JPEG photos and from these you should be able to see how things work.
Basically my hub unit can accommodate 1, 2, 3, 4, 6 and 12 blade options - very useful and allows a quick change of options when experimenting. Also, each blade can be infinitely adjusted from 0-180 degrees either way (left hand prop to right hand prop).The width of blade can be chnaged to suit 50 - 150mm.
From the picture it is direct drive connected to an Ametek 40 volt DC motor and to date I have reached an output of 2.5 volts!
Not sure if I am working the photo upload correctly!
The prop unit contains a lot of inertia and is quick to respond to the slightest wind when 6 blades are fitted. Clearly the shaft turning speed is not fast enough so I have engaged a local machine shop to make up some parts that will allow me to fit the Derailleur gear system from a bicycle onto the rotor and motor unit. Once again I will have a choice of gear selections.
Dave HK
