Just finished this generator today,
It uses the stepper motors similar to the alternators at
http://www.renewablecomponents.com/ , I got one cheap for £35 but the iron in it caused a lot of loss meaning you could hardly turn the shaft by hand.
It turned out to be 16 pole 3 phase, its supported by the shaft.
The fact that it was a large generator with a shaft that could barely be turned, the voltage was 14v per 100rpm , it wasnt suitable at all as is for the 4' dia prop that I wanted.
So after lots of thought, I chopped out the stator and cleaned the shaft off. I bought a large chunk of nylon off ebay, 150mm dia * 40mm long and machined it to accept the shaft. Then I drilled the slots axially on the outside of the nylon to accept the coils. ;
I calculated the required wire based on the original slot fill and assumed half flux density, I came out with 0.69mm wire 44 turns, I bought 500g of 0.71mm copper wire off ebay, the extra size doesnt harm anything. It turned out that I didnt need much of the 500g and have plenty left for other projects.
The wiring of the coils took a couple hours and I had to make sure there was nothing touching etc which took a while longer, its a single layer winding 3 phase with each phase having 4 coils, its wired in star. I havent got a tachometer although I ordered one from china which will be arriving in a few days, but I estimated 180rpm as the fastest I could spin the case and at that speed got the equivalent of 7.8vdc , this matches well with the target rpm of 270rpm.
Spinning it very fast it will light a 12v bulb across two of the phases. It spins very freely now which is why I did it in the first place. So I'll have to make up a mount for it now, I'll see what happens..
Bump
