Author Topic: what will be the weight of 17'wind turbine blades  (Read 1000 times)
naveed ahmad
« on: July 25, 2005, 05:52:28 AM »
can you tell us what should be the weight of blade . we are building a 17-foot wind turbine.plz help us .thanks
« Last Edit: July 25, 2005, 05:52:28 AM by (unknown) »
Jon Miller
    • Otherpower UK
Re: what will be the weight of 17'wind turbine bla
« Reply #1 on: July 25, 2005, 02:58:17 AM »
A little more information is needed like what are the blades made from?  What design do they follow:  metal center, wood center etc.. Also the dimensions of the blades not just the diameter.  Then people will be able to help you
« Last Edit: July 25, 2005, 02:58:17 AM by Jon Miller »
hvirtane
    • About Solar Cooking
« Reply #2 on: July 25, 2005, 04:50:04 PM »
Hello,
as far as I know,
this machine is supposed to be
a rough copy of
'otherpower' 17 feet machine.
(I was some time ago working
with Naveed Ahmad.)
The blades are being made of fiberglass.
In principle it is best to try making
them as light as possible. So it is a good
idea not to make them of solid fiberglass,
but to use polyurethane inside the blades.
« Last Edit: July 25, 2005, 04:50:04 PM by hvirtane »
DanB
    • otherpower.com
« Reply #3 on: July 28, 2005, 08:47:18 AM »
My machine has blades made from laminated red cedar, all in all the blade set (all 3 blades with hub) weighs around 60 pounds.
Im not sure theres any advantage to making them from fiberglass vs wood... fiberglass has fatigue issues, and I expect they'd come out weighing a bit more than nice wooden ones but hard to say - I have no experience with fiberglass blades.
« Last Edit: July 28, 2005, 08:47:18 AM by DanB »
