Long long ago I bought 24 1.5" x 1/8" round Neos and I think # 16 wire from wondermagnet here.
I have used the mags in various projects since I have had them but never built the wind gennie I actually bought them for.
Over time, way more than a year, wind genies have changed alot. We have gone from single vovlo rotor mills to trailer hub and steel plate daul rotor mills. From 8' blades to 17', 12" brake rotors up to 16" steel plates etc...
So now the question is, what should I build with these mags I have?
I haven't found the page on Other power yet which tells about the mill I was going to build using these to begin with. I think it was a daul rotor volvo mill. These mags and the wire I bought are what was used for that one. My wire is #16 I think or it may be #14, I don't have it here to look at it (it's at the rock house).
If I use 12 per mags per disk what would be recomemended for dia. 12" or larger?
How many windings for the coils if #14 wire or for #16? Also what size should I try for as the inside hole dia. and outer dia. for the coils?
I been trying to find the original gennie on otherpower I had bought these to build, but I have not found that one yet or it was changed perhaps since then? Due to limited net access these days (none where I live now) I'm not online much lattely so searching is slow and hard. Also I figure so much has changed that particalar gennie may not be the best choice today anyway, but I would get much of what I am asking about anyway.
The gennie when built will be primarily used for 12V charging.
Thanks for any sugestions.
Looks like I will be stuck indoors for awhile soon, bad weather comming here in next few days, not as bad as other places will be getting though. Anyway when that weather hits here all my outdoor projects will stop and I figure this will be a good time to build this mill indoors.
