Author Topic: Output of this servo motor?  (Read 832 times)
RedLance
« on: October 23, 2005, 02:54:17 PM »
Greetings!
Check out this motor: http://www.surpluscenter.com/item.asp?UID=2005102309404408&item=10-2206
How much wattage could I expect to get out of this motor?  What size prop would it need to reach maximum output in 10mph average wind speed, and how many blades would you recommend?
I see it also has a 24volt brake on it...that might be useful.
I assume I would need to remove/disable/ignor the encoder?
Thanks for your input!
RedLance
« Last Edit: October 23, 2005, 02:54:17 PM by (unknown) »
Re: Output of this servo motor?
« Reply #1 on: October 23, 2005, 10:18:35 PM »
I noticed that too.
I was thinking of going $5 more for the bigger ones (300w).
Ignore the encoder.
The brake may need removed or disabled.
« Last Edit: October 23, 2005, 10:18:35 PM by ghurd »
