Author Topic: elec fork lift motors 4 wires?  (Read 1381 times)
adelaide
« on: November 08, 2005, 02:00:54 AM »
can get some  elec fork lift motors ,posbly for wind or elec vecle ,i tryed 12 v jumpstarter pac brifly on 2 of 4 termanals it had just sparks no move ment ? same with outher 2 termanals  on a 24 v and a 48 v motor ? is 1 acting like magnet? and outher the motore? or 2 speeds? are they inafishent or good to put neos in ? (next time their will try shorting termanals together and see if hard to turn = perm magnet? any info apreshiated at gess 1 25kg outher 55kg)
« Last Edit: November 08, 2005, 02:00:54 AM by (unknown) »
nanotech
Re: elec fork lift motors 4 wires?
« Reply #1 on: November 07, 2005, 07:09:17 PM »
I would hazard a guess that they are series wound motors, much like the ones for electric cars.
Yes, one set is for the stator windings, one for the rotor windings.
If I have it right, most often they are hooked up :
Rotor + to Stator -
Stator + to power source +
Rotor - to power source -
That way the same voltage contorls both windings equally giving you MUCH more control over speed and torque.
« Last Edit: November 07, 2005, 07:09:17 PM by nanotech »
drdongle
« Reply #2 on: November 07, 2005, 07:16:58 PM »
It's is definatly a series motor and NOT sutable for use in a wind generator.
« Last Edit: November 07, 2005, 07:16:58 PM by drdongle »
adelaide
« Reply #3 on: November 07, 2005, 08:24:18 PM »
ok is it efishent for elec vecle ?
« Last Edit: November 07, 2005, 08:24:18 PM by adelaide »
« Reply #4 on: November 07, 2005, 09:01:38 PM »
By the way:  Never hook 'em up in series for a generator application.  You can end up with the "self-reversing motor" effect, where the generator switches polarity when the output load drops.
« Last Edit: November 07, 2005, 09:01:38 PM by Ungrounded Lightning Rod »
« Reply #5 on: November 07, 2005, 09:02:26 PM »
By this I mean never hook the armature and field of the GENERATOR in series.  Works great for the motor.
« Last Edit: November 07, 2005, 09:02:26 PM by Ungrounded Lightning Rod »
drdongle
« Reply #6 on: November 08, 2005, 06:37:23 AM »
Probably, depends on voltage, RPM, HP, need a gearbox? mounting? numerious issues, like what compromises you are willing or able to make.
« Last Edit: November 08, 2005, 06:37:23 AM by drdongle »
adelaide
« Reply #7 on: November 09, 2005, 01:14:22 AM »
think the rpm was good ,think 2000 or 3000 so put it to cheep car g box or try direct first? are they bad efishancys ?just put some wirtes to bat bank so can wind charge or better something that could swap pacs would be a hard thing to do ,elec scoooter arriving soon is first elec transport .will be wind charged coool
« Last Edit: November 09, 2005, 01:14:22 AM by adelaide »
nickelbender
« Reply #8 on: November 11, 2005, 09:41:16 PM »
If you can pull out the pole shoes and spin new coils this could be of use.
Armatures are a bear to wind but fields are easy. In fact I might be interested in aquiring one of these motors can you give me some more information?
« Last Edit: November 11, 2005, 09:41:16 PM by nickelbender »
