Author Topic: Where to locate bearings  (Read 1842 times)
Japhethwg
« on: February 10, 2006, 12:19:35 AM »
Anyone have any ideas where I could locate bearing that would work with my genny. I'm looking at building a wind generator and am trying to keep it simple and cheap.
I'm following the plans for the generator made almost compleatly from Microwave parts and I'm not sure what kind of bearing is needed for the blades. I would like to keep it as cheap as possable and I was thinking of pulling one out of a car altinator but I'm not sure how I would attach it. Any ideas in this area would be great!
« Last Edit: February 10, 2006, 12:19:35 AM by (unknown) »
zap
  • There's an app for that
Re: Where to locate bearings
« Reply #1 on: February 09, 2006, 05:29:47 PM »
Japhethwg if any of the microwaves you have are hood mounted, check the exhaust fan. These usually have good bearings. Inline skates, kick scooters, etc. also have nice bearings. Keep whatever mounting you find the bearings in to try and use that to mount your blades unless you have access to some type of machining equipment.
« Last Edit: February 09, 2006, 05:29:47 PM by zap »
picmacmillan
« Reply #2 on: February 09, 2006, 06:02:19 PM »
why not an old car spindle? someone would give you one for sure off a junk car, or trailer...lots use those, unless of course you're project is redoing an electric motor, but if i recall from your posts you are making one similar to most of ours...good luck ..looks good so far..pickster
« Last Edit: February 09, 2006, 06:02:19 PM by picmacmillan »
Tom in NH
« Reply #3 on: February 09, 2006, 08:01:23 PM »
I was at my lawn mower repair shop and saw a set of bearings and mounts taken off a riding mower deck. They were still good. The repair guy thought I was doing him a favor taking them off his hands. They went into the skeleton of my current VAWT project. --tom
« Last Edit: February 09, 2006, 08:01:23 PM by Tom in NH »
« Reply #4 on: February 10, 2006, 06:56:19 AM »
  Even if the bearings in the blade spindles
have went bad in the most common 2 blade type
it's usually the bottom ones that go bad first
and even tho' they're sealed the seals go bad
in time and all that dust,chaff, moisture in
the lower part of the deck...really plays heck
with that lower bearing ! ...in the meantime
the top one can be good as new....so if you get
a 2 bladed deck you can make one good spindle
out of 2...probably. The whole spindle can be used,
the blades of your genny can be mounted
with very little modificaation. Where the pulley
is/was can be used to put your plate for the
magnets...if a home brew alternator. Or the
pulley can be used as part of a flexible
coupling.
    That spindle was probably designed for
handling some of the output of a 8 to 18 horse
engine at 2 to 4 thousand revs with the tips
traveling at near sonic speeds...so as part of
a HAWT it should be able to handle 5 or 800 revs.
    ....but if you run across an almost good
bearing ...in my experience, it's a waste of
time to try to salvage it, new bearings are
quiet because they are polished to a mirror
finish...once that surface has become damaged
by dirt or rust ...forget it ...unless you like
the neat sound of ( rrrrrr.rrrr) of a bad bearing
at 2 or 3 in the morning.
    There is also the headset of a bicycle
especially for a VAWT
....coming soon in my diary...
should be entertaining and useful for some..
Thanks for bringing
it up tom...
any pics of your
current project or
did I miss it?
                  ( :>) Norm.
« Last Edit: February 10, 2006, 06:56:19 AM by Norm »
hvirtane
    • About Solar Cooking
bearings of wood and from bicycles
« Reply #5 on: February 10, 2006, 08:05:48 AM »
From a bicycle you can get
quite good bearings.
The one for pedals is often quite
strong. Also the one for steering.
You can make good bearings of wood.
You will put the wood piece inside
used engine oil. Heat the oil
so much that the water inside the
wood will start boiling
and bubbling out. Wait until
that bubbling stops. Let the
wood piece to stay inside
the oil overnight so that the
oil will go inside to replace
the water, which was there.
Drill the suitable hole
for your shaft. Wooden bearings
will have some friction, but
they are good and cheap.
« Last Edit: February 10, 2006, 08:05:48 AM by hvirtane »
zap
« Reply #6 on: February 10, 2006, 08:12:58 AM »
I agree on the bicycles Norm.
It still amazes me when you find a bike in the trash that was rode off and on for 5 years without any kind of maintenance then left outside for another 10 years before being tossed... a little oil here and there, some air in the tires, and the sucker can be rode home!
« Last Edit: February 10, 2006, 08:12:58 AM by zap »
Re: bearings of wood and from bicycles
« Reply #7 on: February 10, 2006, 12:56:45 PM »
   Right Hannu...the 2foot diameter diameter
shaft bearings on one of the ships I was on
were made of wood.
               ( :>0 Norm.
« Last Edit: February 10, 2006, 12:56:45 PM by Norm »
theTinker
« Reply #8 on: February 10, 2006, 04:17:38 PM »
an excellent idea.
« Last Edit: February 10, 2006, 04:17:38 PM by theTinker »
Don Cackleberrycreations
« Reply #9 on: February 10, 2006, 04:44:31 PM »
You can also pour bearings from leno lead
basicly take a candle and let the soot collect on the shaft then pour molten lead .
These were used in a lot of old farm equipemnt and sawmills.
I know a very old farmer who replaced the worn out bearings in his pre 1940s trackter with with an oil soaked leather belt its still chugging along
« Last Edit: February 10, 2006, 04:44:31 PM by Don Cackleberrycreations »
